Введение
If the heat sink in your HP Pavilion x360 11m-ad013dx has stopped working or is in need of replacement, use this guide to replace it. For more information on a malfunctioning heat sink, see our troubleshooting page HP Pavilion x360 11m-ad013dx Troubleshooting. The heat sink performs the same actions as a cooling fan in a PC, but is sleeker and lighter in weight to improve the laptop’s design.
Выберете то, что вам нужно
Using a plastic spudger, remove the grey silicon strip closest to the back-side.
Open the HP Pavilion so that the screen is showing. Then tilt it down so that the screen is on its back, facing up.
Using a spudger, pry off the black keyboard panel.
Using your fingernail, disconnect the zero insertion force (ZIF) keyboard connector cable by flipping up the small locking flap.
Using your fingernail, disconnect the zero insertion force (ZIF) connector for the touch pad cable by flipping up the small locking flap.
Using a spudger for assistance, lift up the right edge of the battery.
Remove the battery.
Using your fingernail, disconnect the ZIF (zero insertion force) hard drive cable by flipping up the small locking flap.
With your fingernails, disconnect the speaker cable from the motherboard by pulling back on the connector.
Using your fingernail, disconnect the ZIF (zero insertion force) power button connector cable from the motherboard.
Using your fingernail, disconnect the ZIF display panel connector cable from the motherboard.
Disconnect the two WLAN antenna cables by sliding under the cable with a spudger, then lifting straight up.
Using your fingernail, disconnect the ZIF display touch screen connector cable from the motherboard.
Using your fingernails, disconnect the power connector cable by pulling straight out.
Lift the motherboard up on the right side. Then, gently pull the motherboard straight out to the right.
Using a tissue or paper towel, clean thermal paste off the heat sink and processor.
