Введение
Below you will find the steps to replace the motherboard for the HP Pavilion x360 11m-ad013dx. Whether you want to upgrade your laptop’s performance or your motherboard is malfunctioning, follow these steps to replace the motherboard. The motherboard, also known as the system board, is a main part of the system, containing the WLAN module, PSU, and memory module. The motherboard also provides access to the heat sink, located on the backside of the motherboard. Be careful when handling the motherboard, as some parts may be delicate.
Выберете то, что вам нужно
Using a plastic spudger, remove the grey silicon strip closest to the back-side.
Open the HP Pavilion so that the screen is showing. Then tilt it down so that the screen is on its back, facing up.
Using a spudger, pry off the black keyboard panel.
Using your fingernail, disconnect the zero insertion force (ZIF) keyboard connector cable by flipping up the small locking flap.
Using your fingernail, disconnect the zero insertion force (ZIF) connector for the touch pad cable by flipping up the small locking flap.
Using a spudger for assistance, lift up the right edge of the battery.
Remove the battery.
Using your fingernail, disconnect the ZIF (zero insertion force) hard drive cable by flipping up the small locking flap.
With your fingernails, disconnect the speaker cable from the motherboard by pulling back on the connector.
Using your fingernail, disconnect the ZIF (zero insertion force) power button connector cable from the motherboard.
Using your fingernail, disconnect the ZIF display panel connector cable from the motherboard.
Disconnect the two WLAN antenna cables by sliding under the cable with a spudger, then lifting straight up.
Using your fingernail, disconnect the ZIF display touch screen connector cable from the motherboard.
Using your fingernails, disconnect the power connector cable by pulling straight out.
Lift the motherboard up on the right side. Then, gently pull the motherboard straight out to the right.
2 участников успешно повторили данное руководство.
