Введение
If the speakers in your HP Pavilion x360 11m-ad013dx are in need of replacement or have stopped functioning properly, use this guide to replace the speakers. For more information about malfunctioning or nonfunctioning speakers, see our troubleshooting page HP Pavilion x360 11m-ad013dx Troubleshooting. The speakers are responsible for producing sound in the laptop. They also give access to work on the motherboard when removed.
Выберете то, что вам нужно
Using a plastic spudger, remove the grey silicon strip closest to the back-side.
Open the HP Pavilion so that the screen is showing. Then tilt it down so that the screen is on its back, facing up.
Using a spudger, pry off the black keyboard panel.
Using your fingernail, disconnect the zero insertion force (ZIF) keyboard connector cable by flipping up the small locking flap.
Using your fingernail, disconnect the zero insertion force (ZIF) connector for the touch pad cable by flipping up the small locking flap.
Using a spudger for assistance, lift up the right edge of the battery.
Remove the battery.
Using your fingernail, disconnect the ZIF (zero insertion force) hard drive cable by flipping up the small locking flap.
With your fingernails, disconnect the speaker cable from the motherboard by pulling back on the connector.
