HP Pavilion x360 14m-ba011dx Screen Replacement
Выберете то, что вам нужно
  1. HP Pavilion x360 14m-ba011dx Screen Replacement, Battery: шаг 1, изображение 1 из 2 HP Pavilion x360 14m-ba011dx Screen Replacement, Battery: шаг 1, изображение 2 из 2
    • Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
    • Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:​
    • Two 7.5 mm screws.
    • Three 5 mm screws.
    • One 6.5 mm screw.
  2. HP Pavilion x360 14m-ba011dx Screen Replacement: шаг 2, изображение 1 из 1
    • Push into the two screw holes that were under the rubber pads with the screwdriver to pop the keyboard out just a little.
    • Do this with the screen open so that you do not damage the screen.
    • Do not remove keyboard all the way.
  3. HP Pavilion x360 14m-ba011dx Screen Replacement: шаг 3, изображение 1 из 2 HP Pavilion x360 14m-ba011dx Screen Replacement: шаг 3, изображение 2 из 2
    • Separate the keyboard from the rest of the device using a metal or plastic spudger around the edges.
    • Pull up gently just until you can see the cables attaching the keyboard to the motherboard.
    • Flip the small white flaps holding the cables to the motherboard open to unplug the cords.
  4. HP Pavilion x360 14m-ba011dx Screen Replacement: шаг 4, изображение 1 из 2 HP Pavilion x360 14m-ba011dx Screen Replacement: шаг 4, изображение 2 из 2
    • Remove the purple cable attaching the battery to the motherboard by flipping the black flap and pulling the cable out.
    • Remove seven 4 mm screws using a Phillips #00 Screwdriver.
  5. HP Pavilion x360 14m-ba011dx Screen Replacement: шаг 5, изображение 1 из 1
    • Remove the battery by gently pushing battery up, then pulling.
  6. HP Pavilion x360 14m-ba011dx Screen Replacement, Screen: шаг 6, изображение 1 из 2 HP Pavilion x360 14m-ba011dx Screen Replacement, Screen: шаг 6, изображение 2 из 2
    • Insert the Jimmy between the screen and back case.
    • Carefully detach the screen from the back case by sliding the Jimmy around the casing and prying the screen from the case.
  7. HP Pavilion x360 14m-ba011dx Screen Replacement: шаг 7, изображение 1 из 2 HP Pavilion x360 14m-ba011dx Screen Replacement: шаг 7, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Купить
    • Using the tweezers, remove the tape securing the connector and gently disconnect the wire.
  8. HP Pavilion x360 14m-ba011dx Screen Replacement: шаг 8, изображение 1 из 2 HP Pavilion x360 14m-ba011dx Screen Replacement: шаг 8, изображение 2 из 2
    • Using the tweezers, remove the right side connector from the connector port and free the wiring from right to left.
  9. HP Pavilion x360 14m-ba011dx Screen Replacement: шаг 9, изображение 1 из 2 HP Pavilion x360 14m-ba011dx Screen Replacement: шаг 9, изображение 2 из 2
    • Using the tweezers, remove the left side connector from the connector port and ensure all tape securing the wiring harness is free.
    • Remove the screen from the rest of the laptop.
Заключение
Christopher Joseph McGinnis
Участник с: 09/20/21
109 Репутация
1 руководство автора
Команда
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 28
За всё время: 857
