HP Pavilion x360 14m-ba011dx Touchpad Replacement
Выберете то, что вам нужно
  1. HP Pavilion x360 14m-ba011dx Touchpad Replacement, Touchpad: шаг 1, изображение 1 из 2 HP Pavilion x360 14m-ba011dx Touchpad Replacement, Touchpad: шаг 1, изображение 2 из 2
    • Remove the top left and right rubber pads closest to the hinge of the screen using a plastic spudger to locate the screws underneath. ​
    • Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:
    • Remove two 7.5 mm screws.
    • Remove three 5 mm screws.
    • Remove one 6.5 mm screw.
  2. HP Pavilion x360 14m-ba011dx Touchpad Replacement: шаг 2, изображение 1 из 1
    • Push into the two screw holes located under the rubber pads with the screwdriver to pop the keyboard out slightly.
    • Do this with the screen open so that you do not damage the screen.
    • Do not remove the keyboard all the way.
  3. HP Pavilion x360 14m-ba011dx Touchpad Replacement: шаг 3, изображение 1 из 2 HP Pavilion x360 14m-ba011dx Touchpad Replacement: шаг 3, изображение 2 из 2
    • Separate the keyboard from the rest of the device using a metal spudger around edges.
    • Pull up gently until you can see the cables attaching the keyboard to the motherboard.
    • Flip the small white clasps that hold the three cables to the motherboard open and unplug the cables.
  4. HP Pavilion x360 14m-ba011dx Touchpad Replacement: шаг 4, изображение 1 из 2 HP Pavilion x360 14m-ba011dx Touchpad Replacement: шаг 4, изображение 2 из 2
    • Flip the now removed keyboard over to expose the bottom side.
    • Unclasp the cable that connects the touchpad to the keyboard.
    • You can remove this cable the same way you removed the previous cables.
    • Remove the six 2.3 mm screws that attach the touch pad using a Phillips #00 Screwdriver.
  5. HP Pavilion x360 14m-ba011dx Touchpad Replacement: шаг 5, изображение 1 из 2 HP Pavilion x360 14m-ba011dx Touchpad Replacement: шаг 5, изображение 2 из 2
    • Pull off the metal piece holding the touchpad in place.
    • Remove the touchpad from the device.
Заключение
Katie Pruis
Участник с: 01/16/20
799 Репутация
Автор 5 руководств
Команда
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 24
За всё время: 1,510
