Введение
Use this guide to aid in the removal and replacement of the back cover to any HP Pavilion x360 14m-cd0005dx laptop. If there are ever any cracks or issues with it closing fully, a full replacement might be necessary.
The back cover is generally removed for any significant modifications or repair to a computer. The back cover comes off and goes back on relatively quickly. Luckily, replacing the back cover is reasonably quick and easy; it also has minimal risk of damage to the device.
Выберете то, что вам нужно
Turn off and shut down the computer.
Disconnect the power adapter and all external devices connected to the computer.
Use the opening tool to remove the rubber feet attached to the bottom of the device.
Remove all screws located on the bottom of the device:
Two Phillips #0 7.0mm screws
Three Phillips #00 4.5mm screws
