Введение
Use this guide to replace the keyboard in your HP Pavilion x360 15t-br000 laptop.
If your keyboard is damaged, you can not type text into the laptop.Thus, you can not operate normally on your laptop with a damaged keyboard.
Remember to shut down the laptop when doing the replacement.
Выберете то, что вам нужно
Remove the covers to access the screws attached to the back cover of the device.
Remove six 3mm screws using the Phillips #0 screwdriver.
Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
Disconnect the keyboard panel cables under the upper case.
Remove the keyboard panel from the device.
Remove the two tapes of connected with the track board and the keyboard panel.
Remove the seven 2mm screws using the Phillips #0 screwdriver.
Remove the trackpad from the device.
