Введение
This guide will show you how to take out and replace the motherboard in the HP Pavilion x360 15t-br000 laptop.
The motherboard is the backbone which ties all of the key components of the computer together. A dysfunctional motherboard can cause many problems such as computer crashes, screen freezes, or causing connected devices to no longer work.
Remember to shut down the computer before beginning the replacement.
Выберете то, что вам нужно
Remove the covers to access the screws attached to the back cover of the device.
Remove six 3mm screws using the Phillips #0 screwdriver.
Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
Disconnect the keyboard panel cables under the upper case.
Remove the keyboard panel from the device.
Unscrew the nine 3mm mounting screws on the motherboard using the Phillips #0 screwdriver.
