HP Pavilion x360 m3-u001dx Battery Replacement
Выберете то, что вам нужно
  1. HP Pavilion x360 m3-u001dx Battery Replacement, Keyboard: шаг 1, изображение 1 из 1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u001dx Battery Replacement: шаг 2, изображение 1 из 2 HP Pavilion x360 m3-u001dx Battery Replacement: шаг 2, изображение 2 из 2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u001dx Battery Replacement: шаг 3, изображение 1 из 1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u001dx Battery Replacement: шаг 4, изображение 1 из 1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u001dx Battery Replacement: шаг 5, изображение 1 из 2 HP Pavilion x360 m3-u001dx Battery Replacement: шаг 5, изображение 2 из 2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u001dx Battery Replacement: шаг 6, изображение 1 из 1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u001dx Battery Replacement: шаг 7, изображение 1 из 1
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u001dx Battery Replacement: шаг 8, изображение 1 из 1
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u001dx Battery Replacement, Battery: шаг 9, изображение 1 из 1
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u001dx Battery Replacement: шаг 10, изображение 1 из 1
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
Заключение
Follow these instructions in reverse order to reassemble your device.
7 участников успешно повторили данное руководство.
Subhleen
Участник с: 02/01/17
1 268 Репутация
Автор 5 руководств
Команда
UW Tacoma, Team 1-6, Rose Winter 2017 Участник UW Tacoma, Team 1-6, Rose Winter 2017
UWT-ROSE-W17S1G6
4 членов
Автор 8 руководств
2 Комментариев
Thanks for this easy step by step guide. The pictures were incredibly helpful!
azbeasleys - Ответить
I replaced the battery now the screen doesn't turn on. I plugged it into an external monitor and the computer works fine and even the touch aspect of the screen works, but it stays black. Did i accidentally disconnect something?
G Bates - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 7,245
