HP Pavilion x360 m3-u001dx Display Replacement
Выберете то, что вам нужно
  1. HP Pavilion x360 m3-u001dx Display Replacement, Keyboard: шаг 1, изображение 1 из 1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u001dx Display Replacement: шаг 2, изображение 1 из 2 HP Pavilion x360 m3-u001dx Display Replacement: шаг 2, изображение 2 из 2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u001dx Display Replacement: шаг 3, изображение 1 из 1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
    “5 Phillips 2.4 x 5.7 mm screws”
    “5 Phillips 2.0 x 5.0 mm screws”
    I think the color for the sizes are mixed up, because the one near the screen bending part are the bigger ones, yet it says they are the “2.0 x 5.0 mm” but they are the bigger ones.
    If I’m wrong, tell me because I’m not sure if thats the ways they’re named because I’m not an expert at screw sizes.
    SomeRandomChild - Ответить
  4. HP Pavilion x360 m3-u001dx Display Replacement: шаг 4, изображение 1 из 1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u001dx Display Replacement: шаг 5, изображение 1 из 2 HP Pavilion x360 m3-u001dx Display Replacement: шаг 5, изображение 2 из 2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u001dx Display Replacement: шаг 6, изображение 1 из 1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u001dx Display Replacement: шаг 7, изображение 1 из 1
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u001dx Display Replacement: шаг 8, изображение 1 из 1
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u001dx Display Replacement, Battery: шаг 9, изображение 1 из 1
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u001dx Display Replacement: шаг 10, изображение 1 из 1
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  11. HP Pavilion x360 m3-u001dx Display Replacement, USB Port Shield: шаг 11, изображение 1 из 3 HP Pavilion x360 m3-u001dx Display Replacement, USB Port Shield: шаг 11, изображение 2 из 3 HP Pavilion x360 m3-u001dx Display Replacement, USB Port Shield: шаг 11, изображение 3 из 3
    • (You don't NEED to remove this shielding as you can remove the board with it still there.)
    • Remove the adhesive strip.
    • Lift the shield away from the base of the laptop.
    This step is not relevant or required...
    ETHREAL1 - Ответить
  12. HP Pavilion x360 m3-u001dx Display Replacement, System Board (Motherboard): шаг 12, изображение 1 из 3 HP Pavilion x360 m3-u001dx Display Replacement, System Board (Motherboard): шаг 12, изображение 2 из 3 HP Pavilion x360 m3-u001dx Display Replacement, System Board (Motherboard): шаг 12, изображение 3 из 3
    • Disconnect the ribbon cables attached to the system board (motherboard).
    • Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  13. HP Pavilion x360 m3-u001dx Display Replacement: шаг 13, изображение 1 из 2 HP Pavilion x360 m3-u001dx Display Replacement: шаг 13, изображение 2 из 2
    • Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger.
  14. HP Pavilion x360 m3-u001dx Display Replacement: шаг 14, изображение 1 из 2 HP Pavilion x360 m3-u001dx Display Replacement: шаг 14, изображение 2 из 2
    • Pull the clipped cables from system board (motherboard).
  15. HP Pavilion x360 m3-u001dx Display Replacement: шаг 15, изображение 1 из 3 HP Pavilion x360 m3-u001dx Display Replacement: шаг 15, изображение 2 из 3 HP Pavilion x360 m3-u001dx Display Replacement: шаг 15, изображение 3 из 3
    • Remove the system board (motherboard).
    • Using the Phillips 00 Screw Driver, remove 9 Phillips 2.0 x 4.7 mm screws with "M2L4" next to them.
    • Using the Phillips 00 Screw Driver, remove the silver screw.
  16. HP Pavilion x360 m3-u001dx Display Replacement: шаг 16, изображение 1 из 1
    • Carefully lift the front side of the system board (motherboard).
    this step i do not understand. because you do no have to remove the motherboard for a screen replacement.
    Akeem Scrubb - Ответить
    This is the procedure for replacing the FAN, not the screen, and the board absolutely must be removed to replace the fan.
    Dennis Fain -
  17. HP Pavilion x360 m3-u001dx Display Replacement: шаг 17, изображение 1 из 1
    • Using a Heavy Duty Spudger, disconnect the black and red RTC battery cable on the left side of the system board (motherboard).
  18. HP Pavilion x360 m3-u001dx Display Replacement: шаг 18, изображение 1 из 1
    • Release the system board (motherboard) from the base enclosure.
    • Place the motherboard somewhere safe since it is the most delicate and expensive part of the laptop.
  19. HP Pavilion x360 m3-u001dx Display Replacement, Display: шаг 19, изображение 1 из 1
    • Using the Phillips 00 Screw Driver, remove 5 Phillips 2.5 x 4.2 screws from the hinges from the laptop's base.
  20. HP Pavilion x360 m3-u001dx Display Replacement: шаг 20, изображение 1 из 2 HP Pavilion x360 m3-u001dx Display Replacement: шаг 20, изображение 2 из 2
    • Gently pull the display away from the base panel to unhinge.
  21. HP Pavilion x360 m3-u001dx Display Replacement: шаг 21, изображение 1 из 1
    • Use a Metal Spudger to pry the display panel from the outer casing.
    • Start from the top of the display panel and move along the edges and do not to push the metal spudger too far into the screen.
    • Be cautious not to apply heavy pressure to the display panel. This could damage the touch screen.
    If this is all it takes to take apart the display, why did we go through the whole process of removing the motherboard?
    Joshua Hamlett - Ответить
  22. HP Pavilion x360 m3-u001dx Display Replacement: шаг 22, изображение 1 из 1
    • Open the display panel to expose the connecting cables.
    • Open carefully to avoid causing damage to the connecting cables.
  23. HP Pavilion x360 m3-u001dx Display Replacement: шаг 23, изображение 1 из 2 HP Pavilion x360 m3-u001dx Display Replacement: шаг 23, изображение 2 из 2
    • Peel off the adhesive tape and remove the connected cable from the screen.
  24. HP Pavilion x360 m3-u001dx Display Replacement: шаг 24, изображение 1 из 2 HP Pavilion x360 m3-u001dx Display Replacement: шаг 24, изображение 2 из 2
    • Lift the circuit board out of the way to expose the wire underneath. Remove the wire from the base of the laptop.
    Do the LCD s come with new circuit boards
    Adam Johnson - Ответить
Заключение
Follow these instructions in reverse order to reassemble your device.
5 участников успешно повторили данное руководство.
_ thinhh@uw.edu
Участник с: 02/01/17
297 Репутация
Автор 2 руководств
Команда
UW Tacoma, Team 1-6, Rose Winter 2017 Участник UW Tacoma, Team 1-6, Rose Winter 2017
UWT-ROSE-W17S1G6
4 членов
Автор 8 руководств
5 Комментариев
Question, why not just do step 21 on?
ETHREAL1 - Ответить
You can. Fold the computer all the way over and go from there. The only advantage to opening the bottom would be to disconnect the battery: a highly recommended procedure.
Corvallis Computer - Ответить
A little extra pulling the mother board out. But I guess better safe then sorry. All in all this was a good guide!
Brandon Courtney - Ответить
REMEMBER if your new touch screen does not work (no touch screen) go into the device manager and uninstall i2c hid device. restart the laptop and the driver (and touch) should work again.
I was able to install a new screen. However, the “touch” does not work. I tried the uninstall i2c hid (and also HID- compliant touch screen) trick, but no luck. My guess is its my fault during install. Before I go diving back in for a loose connection, does anyone know which connection I should focus on?
allynz - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 17
За всё время: 7,233
