HP Pavilion x360 m3-u001dx Fan Replacement
Выберете то, что вам нужно
  1. HP Pavilion x360 m3-u001dx Fan Replacement, Keyboard: шаг 1, изображение 1 из 1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u001dx Fan Replacement: шаг 2, изображение 1 из 2 HP Pavilion x360 m3-u001dx Fan Replacement: шаг 2, изображение 2 из 2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u001dx Fan Replacement: шаг 3, изображение 1 из 1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
    “5 Phillips 2.4 x 5.7 mm screws”
    “5 Phillips 2.0 x 5.0 mm screws”
    I think the color for the sizes are mixed up, because the one near the screen bending part are the bigger ones, yet it says they are the “2.0 x 5.0 mm” but they are the bigger ones.
    If I’m wrong, tell me because I’m not sure if thats the ways they’re named because I’m not an expert at screw sizes.
    SomeRandomChild - Ответить
  4. HP Pavilion x360 m3-u001dx Fan Replacement: шаг 4, изображение 1 из 1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u001dx Fan Replacement: шаг 5, изображение 1 из 2 HP Pavilion x360 m3-u001dx Fan Replacement: шаг 5, изображение 2 из 2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u001dx Fan Replacement: шаг 6, изображение 1 из 1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u001dx Fan Replacement: шаг 7, изображение 1 из 1
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u001dx Fan Replacement: шаг 8, изображение 1 из 1
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u001dx Fan Replacement, Battery: шаг 9, изображение 1 из 1
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u001dx Fan Replacement: шаг 10, изображение 1 из 1
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  11. HP Pavilion x360 m3-u001dx Fan Replacement, USB Port Shield: шаг 11, изображение 1 из 3 HP Pavilion x360 m3-u001dx Fan Replacement, USB Port Shield: шаг 11, изображение 2 из 3 HP Pavilion x360 m3-u001dx Fan Replacement, USB Port Shield: шаг 11, изображение 3 из 3
    • (You don't NEED to remove this shielding as you can remove the board with it still there.)
    • Remove the adhesive strip.
    • Lift the shield away from the base of the laptop.
    This step is not relevant or required...
    ETHREAL1 - Ответить
  12. HP Pavilion x360 m3-u001dx Fan Replacement, System Board (Motherboard): шаг 12, изображение 1 из 3 HP Pavilion x360 m3-u001dx Fan Replacement, System Board (Motherboard): шаг 12, изображение 2 из 3 HP Pavilion x360 m3-u001dx Fan Replacement, System Board (Motherboard): шаг 12, изображение 3 из 3
    • Disconnect the ribbon cables attached to the system board (motherboard).
    • Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  13. HP Pavilion x360 m3-u001dx Fan Replacement: шаг 13, изображение 1 из 2 HP Pavilion x360 m3-u001dx Fan Replacement: шаг 13, изображение 2 из 2
    • Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger.
  14. HP Pavilion x360 m3-u001dx Fan Replacement: шаг 14, изображение 1 из 2 HP Pavilion x360 m3-u001dx Fan Replacement: шаг 14, изображение 2 из 2
    • Pull the clipped cables from system board (motherboard).
  15. HP Pavilion x360 m3-u001dx Fan Replacement: шаг 15, изображение 1 из 3 HP Pavilion x360 m3-u001dx Fan Replacement: шаг 15, изображение 2 из 3 HP Pavilion x360 m3-u001dx Fan Replacement: шаг 15, изображение 3 из 3
    • Remove the system board (motherboard).
    • Using the Phillips 00 Screw Driver, remove 9 Phillips 2.0 x 4.7 mm screws with "M2L4" next to them.
    • Using the Phillips 00 Screw Driver, remove the silver screw.
  16. HP Pavilion x360 m3-u001dx Fan Replacement: шаг 16, изображение 1 из 1
    • Carefully lift the front side of the system board (motherboard).
    this step i do not understand. because you do no have to remove the motherboard for a screen replacement.
    Akeem Scrubb - Ответить
    This is the procedure for replacing the FAN, not the screen, and the board absolutely must be removed to replace the fan.
    Dennis Fain -
  17. HP Pavilion x360 m3-u001dx Fan Replacement: шаг 17, изображение 1 из 1
    • Using a Heavy Duty Spudger, disconnect the black and red RTC battery cable on the left side of the system board (motherboard).
  18. HP Pavilion x360 m3-u001dx Fan Replacement: шаг 18, изображение 1 из 1
    • Release the system board (motherboard) from the base enclosure.
    • Place the motherboard somewhere safe since it is the most delicate and expensive part of the laptop.
  19. HP Pavilion x360 m3-u001dx Fan Replacement, Fan: шаг 19, изображение 1 из 1
  20. HP Pavilion x360 m3-u001dx Fan Replacement: шаг 20, изображение 1 из 1
    • Using the Phillips 00 Screw Driver. remove 4 screws from the heat sink.
  21. HP Pavilion x360 m3-u001dx Fan Replacement: шаг 21, изображение 1 из 1
    • Remove any adhesive tape attaching the fan/heat sink to the system board (motherboard).
    • The grey paste under the fan/heat sink is thermopaste, it keeps the processor cool. To replace it, use our How to Apply Thermal Paste guide.
    • Detach the fan/heat sink.
Заключение
Follow these instructions in reverse order to reassemble your device.
8 участников успешно повторили данное руководство.
Jonathan
Участник с: 02/01/17
245 Репутация
1 руководство автора
Команда
UW Tacoma, Team 1-6, Rose Winter 2017 Участник UW Tacoma, Team 1-6, Rose Winter 2017
UWT-ROSE-W17S1G6
4 членов
Автор 8 руководств
3 Комментариев
Great step-by-step instructions. Thank you
mistyjohn - Ответить
While it took us much longer than 7-9 minutes, the guide was fantastic and we were able to fix our computer. Thank you!
Bronwyn Dasher - Ответить
Took me way longer than 7-9 minutes and would’ve been cool if that heat paste was mentioned in the ‘Tools’ or ‘Parts’ sections at the top. Granted I probably should’ve read the guide completely before beginning, I got all the way to the end and realized I didn’t have the paste and couldn’t finish the job. I also would’ve liked to see something about removing the black part from the fan or actually putting the new fan in. Overall, the guide was very helpful and easy to follow and for that, I do thank you.
Allison Lewis - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 6,138
