Введение
If the laptop is hotter than usual or is making noises, use this guide to replace the fan.
Выберете то, что вам нужно
Shut down the computer.
Disconnect the power and all external devices connected to the computer.
Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
Remove all of the screws located on the bottom of the laptop:
5 Phillips 2.4 x 5.7 mm screws
5 Phillips 2.0 x 5.0 mm screws
“5 Phillips 2.4 x 5.7 mm screws”
“5 Phillips 2.0 x 5.0 mm screws”
I think the color for the sizes are mixed up, because the one near the screen bending part are the bigger ones, yet it says they are the “2.0 x 5.0 mm” but they are the bigger ones.
If I’m wrong, tell me because I’m not sure if thats the ways they’re named because I’m not an expert at screw sizes.
Turn the computer over onto its base, with the computer open and the keyboard facing upward.
Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
(You don't NEED to remove this shielding as you can remove the board with it still there.)
Remove the adhesive strip.
Lift the shield away from the base of the laptop.
Disconnect the ribbon cables attached to the system board (motherboard).
Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger.
Remove the system board (motherboard).
Using the Phillips 00 Screw Driver, remove 9 Phillips 2.0 x 4.7 mm screws with "M2L4" next to them.
Using the Phillips 00 Screw Driver, remove the silver screw.
this step i do not understand. because you do no have to remove the motherboard for a screen replacement.
This is the procedure for replacing the FAN, not the screen, and the board absolutely must be removed to replace the fan.
Using a Heavy Duty Spudger, disconnect the black and red RTC battery cable on the left side of the system board (motherboard).
Remove any adhesive tape attaching the fan/heat sink to the system board (motherboard).
Detach the fan/heat sink.
Follow these instructions in reverse order to reassemble your device.
8 участников успешно повторили данное руководство.
3 Комментариев
While it took us much longer than 7-9 minutes, the guide was fantastic and we were able to fix our computer. Thank you!
Took me way longer than 7-9 minutes and would’ve been cool if that heat paste was mentioned in the ‘Tools’ or ‘Parts’ sections at the top. Granted I probably should’ve read the guide completely before beginning, I got all the way to the end and realized I didn’t have the paste and couldn’t finish the job. I also would’ve liked to see something about removing the black part from the fan or actually putting the new fan in. Overall, the guide was very helpful and easy to follow and for that, I do thank you.
