HP Pavilion x360 m3-u001dx Hard Drive Replacement
Выберете то, что вам нужно
  1. HP Pavilion x360 m3-u001dx Hard Drive Replacement, Keyboard: шаг 1, изображение 1 из 1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u001dx Hard Drive Replacement: шаг 2, изображение 1 из 2 HP Pavilion x360 m3-u001dx Hard Drive Replacement: шаг 2, изображение 2 из 2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u001dx Hard Drive Replacement: шаг 3, изображение 1 из 1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u001dx Hard Drive Replacement: шаг 4, изображение 1 из 1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u001dx Hard Drive Replacement: шаг 5, изображение 1 из 2 HP Pavilion x360 m3-u001dx Hard Drive Replacement: шаг 5, изображение 2 из 2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u001dx Hard Drive Replacement: шаг 6, изображение 1 из 1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u001dx Hard Drive Replacement: шаг 7, изображение 1 из 1
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u001dx Hard Drive Replacement: шаг 8, изображение 1 из 1
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u001dx Hard Drive Replacement, Battery: шаг 9, изображение 1 из 1
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u001dx Hard Drive Replacement: шаг 10, изображение 1 из 1
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  11. HP Pavilion x360 m3-u001dx Hard Drive Replacement, Hard Drive: шаг 11, изображение 1 из 1
    • Disconnect the ribbon cables attaching the hard drive to the system board (motherboard).
    • Use the purple plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  12. HP Pavilion x360 m3-u001dx Hard Drive Replacement: шаг 12, изображение 1 из 2 HP Pavilion x360 m3-u001dx Hard Drive Replacement: шаг 12, изображение 2 из 2
    • Using the Phillips00 Screw Driver, remove 4 Phillips 2.0 x 4.6 mm screws around the perimeter of the hard drive.
  13. HP Pavilion x360 m3-u001dx Hard Drive Replacement: шаг 13, изображение 1 из 1
    • Using the tab provided, lift and remove the hard drive out of the laptop base.
  14. HP Pavilion x360 m3-u001dx Hard Drive Replacement: шаг 14, изображение 1 из 2 HP Pavilion x360 m3-u001dx Hard Drive Replacement: шаг 14, изображение 2 из 2
    • Using the Phillips00 Screw Driver, remove 4 Phillips 3.0 x 3.7 mm screws on exterior mounting bracket.
    • There are 2 Phillips screws on each side of the hard drive bracket.
  15. HP Pavilion x360 m3-u001dx Hard Drive Replacement: шаг 15, изображение 1 из 1
    • Remove the mounting bracket.
Заключение
Follow these instructions in reverse order to reassemble your device.
9 участников успешно повторили данное руководство.
Subhleen
Участник с: 02/01/17
1 268 Репутация
Автор 5 руководств
Команда
UW Tacoma, Team 1-6, Rose Winter 2017 Участник UW Tacoma, Team 1-6, Rose Winter 2017
UWT-ROSE-W17S1G6
4 членов
Автор 8 руководств
8 Комментариев
Awesome. Thanks. This helped me a lot.
Gouse Khan - Ответить
Can anyone tell me the model number of the hdd ribbon cable please :)
James Harris - Ответить
I need to replace the data ribbon as well.
KurwynK -
Found it. part# 856011–001
KurwynK - Ответить
My HP Pavilion X360 M3-u00ldx is not recognizing my brand new Samsung 860 Evo 500GB ssd. Upon start up I get  3F0 error which states there is no hard drive. When I boot to a Windows 10 disc it also doesn't recognize it.
Any suggestions on how it can be recognized is appreciated.
Thank you for looking.
downdog89 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 66
За всё время: 22,244
