Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If the hard drive is malfunctioning or needs to be upgraded, use this guide to replace it.
Выберете то, что вам нужно
Shut down the computer.
Disconnect the power and all external devices connected to the computer.
Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
Remove all of the screws located on the bottom of the laptop:
5 Phillips 2.4 x 5.7 mm screws
5 Phillips 2.0 x 5.0 mm screws
Turn the computer over onto its base, with the computer open and the keyboard facing upward.
Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
Disconnect the ribbon cables attaching the hard drive to the system board (motherboard).
Use the purple plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
Using the Phillips00 Screw Driver, remove 4 Phillips 2.0 x 4.6 mm screws around the perimeter of the hard drive.
Using the Phillips00 Screw Driver, remove 4 Phillips 3.0 x 3.7 mm screws on exterior mounting bracket.
Follow these instructions in reverse order to reassemble your device.
9 участников успешно повторили данное руководство.
8 Комментариев
Awesome. Thanks. This helped me a lot.
Can anyone tell me the model number of the hdd ribbon cable please :)
I need to replace the data ribbon as well.
KurwynK -
My HP Pavilion X360 M3-u00ldx is not recognizing my brand new Samsung 860 Evo 500GB ssd. Upon start up I get 3F0 error which states there is no hard drive. When I boot to a Windows 10 disc it also doesn't recognize it.
Any suggestions on how it can be recognized is appreciated.
Thank you for looking.
