Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
If the speakers are malfunctioning, use this guide to replace them.
  1. Shut down the computer.
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. Use a Metal Spudger and  remove the rubber foot closet from the bottom  of the  laptop. Use a Metal Spudger and  remove the rubber foot closet from the bottom  of the  laptop.
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. Remove all  of the screws located on the bottom of the laptop:
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. Turn the computer over onto its base, with the computer open and the keyboard facing upward.
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard. Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. Lift the keyboard away from the base of the laptop.
    • Lift the keyboard away from the base of the laptop.
  9. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  10. Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  11. Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  12. (You don't NEED to remove this shielding as you can remove the board with it still there.) Remove the adhesive strip. Lift the shield away from the base of the laptop.
    • (You don't NEED to remove this shielding as you can remove the board with it still there.)
    • Remove the adhesive strip.
    • Lift the shield away from the base of the laptop.
  13. Disconnect the ribbon cables attached to the system board (motherboard). Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard. Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
    • Disconnect the ribbon cables attached to the system board (motherboard).
    • Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  14. Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger. Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger.
    • Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger.
  15. Pull the clipped cables from system board (motherboard). Pull the clipped cables from system board (motherboard).
    • Pull the clipped cables from system board (motherboard).
  16. Remove the system board (motherboard). Using the Phillips 00 Screw Driver, remove 9 Phillips 2.0 x 4.7 mm screws with "M2L4" next to them. Using the Phillips 00 Screw Driver, remove the silver screw.
    • Remove the system board (motherboard).
    • Using the Phillips 00 Screw Driver, remove 9 Phillips 2.0 x 4.7 mm screws with "M2L4" next to them.
    • Using the Phillips 00 Screw Driver, remove the silver screw.
  17. Carefully lift the front side of the system board (motherboard).
    • Carefully lift the front side of the system board (motherboard).
  18. Using a Heavy Duty Spudger, disconnect the black and red RTC battery cable on the left side of the system board (motherboard).
    • Using a Heavy Duty Spudger, disconnect the black and red RTC battery cable on the left side of the system board (motherboard).
  19. Release the system board (motherboard) from the base enclosure.
    • Release the system board (motherboard) from the base enclosure.
    • Place the motherboard somewhere safe since it is the most delicate and expensive part of the laptop.
  20. Remove the cable from its routing path.
    • Remove the cable from its routing path.
  21. Remove the 2 Phillips 3.0 x 5.6 mm screws. Remove the 2 Phillips 3.0 x 5.6 mm screws.
    • Remove the 2 Phillips 3.0 x 5.6 mm screws.
  22. Carefully peel back the foil as necessary to free the speaker cable from the base of the laptop.
    • Carefully peel back the foil as necessary to free the speaker cable from the base of the laptop.
  23. Lift the speakers away from the base of the laptop.
    • Lift the speakers away from the base of the laptop.
Заключение
Follow these instructions in reverse order to reassemble your device.
Subhleen
Участник с: 01.02.2017
1 129 Репутация
Автор 5 руководств
Команда
UW Tacoma, Team 1-6, Rose Winter 2017 Участник UW Tacoma, Team 1-6, Rose Winter 2017
UWT-ROSE-W17S1G6
4 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 371
