HP Pavilion x360 m3-u001dx System Board Replacement
Выберете то, что вам нужно
  1. HP Pavilion x360 m3-u001dx System Board Replacement, Keyboard: шаг 1, изображение 1 из 1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u001dx System Board Replacement: шаг 2, изображение 1 из 2 HP Pavilion x360 m3-u001dx System Board Replacement: шаг 2, изображение 2 из 2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u001dx System Board Replacement: шаг 3, изображение 1 из 1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u001dx System Board Replacement: шаг 4, изображение 1 из 1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u001dx System Board Replacement: шаг 5, изображение 1 из 2 HP Pavilion x360 m3-u001dx System Board Replacement: шаг 5, изображение 2 из 2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u001dx System Board Replacement: шаг 6, изображение 1 из 1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u001dx System Board Replacement: шаг 7, изображение 1 из 1
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u001dx System Board Replacement: шаг 8, изображение 1 из 1
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u001dx System Board Replacement, Battery: шаг 9, изображение 1 из 1
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u001dx System Board Replacement: шаг 10, изображение 1 из 1
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  11. HP Pavilion x360 m3-u001dx System Board Replacement, USB Port Shield: шаг 11, изображение 1 из 3 HP Pavilion x360 m3-u001dx System Board Replacement, USB Port Shield: шаг 11, изображение 2 из 3 HP Pavilion x360 m3-u001dx System Board Replacement, USB Port Shield: шаг 11, изображение 3 из 3
    • (You don't NEED to remove this shielding as you can remove the board with it still there.)
    • Remove the adhesive strip.
    • Lift the shield away from the base of the laptop.
  12. HP Pavilion x360 m3-u001dx System Board Replacement, System Board (Motherboard): шаг 12, изображение 1 из 3 HP Pavilion x360 m3-u001dx System Board Replacement, System Board (Motherboard): шаг 12, изображение 2 из 3 HP Pavilion x360 m3-u001dx System Board Replacement, System Board (Motherboard): шаг 12, изображение 3 из 3
    • Disconnect the ribbon cables attached to the system board (motherboard).
    • Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  13. HP Pavilion x360 m3-u001dx System Board Replacement: шаг 13, изображение 1 из 2 HP Pavilion x360 m3-u001dx System Board Replacement: шаг 13, изображение 2 из 2
    • Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger.
  14. HP Pavilion x360 m3-u001dx System Board Replacement: шаг 14, изображение 1 из 2 HP Pavilion x360 m3-u001dx System Board Replacement: шаг 14, изображение 2 из 2
    • Pull the clipped cables from system board (motherboard).
  15. HP Pavilion x360 m3-u001dx System Board Replacement: шаг 15, изображение 1 из 3 HP Pavilion x360 m3-u001dx System Board Replacement: шаг 15, изображение 2 из 3 HP Pavilion x360 m3-u001dx System Board Replacement: шаг 15, изображение 3 из 3
    • Remove the system board (motherboard).
    • Using the Phillips 00 Screw Driver, remove 9 Phillips 2.0 x 4.7 mm screws with "M2L4" next to them.
    • Using the Phillips 00 Screw Driver, remove the silver screw.
  16. HP Pavilion x360 m3-u001dx System Board Replacement: шаг 16, изображение 1 из 1
    • Carefully lift the front side of the system board (motherboard).
  17. HP Pavilion x360 m3-u001dx System Board Replacement: шаг 17, изображение 1 из 1
    • Using a Heavy Duty Spudger, disconnect the black and red RTC battery cable on the left side of the system board (motherboard).
  18. HP Pavilion x360 m3-u001dx System Board Replacement: шаг 18, изображение 1 из 1
    • Release the system board (motherboard) from the base enclosure.
    • Place the motherboard somewhere safe since it is the most delicate and expensive part of the laptop.
Заключение
Follow these instructions in reverse order to reassemble your device.
3 участников успешно повторили данное руководство.
_ thinhh@uw.edu
Участник с: 02/01/17
297 Репутация
Автор 2 руководств
Команда
UW Tacoma, Team 1-6, Rose Winter 2017 Участник UW Tacoma, Team 1-6, Rose Winter 2017
UWT-ROSE-W17S1G6
4 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 14
За всё время: 3,852
