Введение
Make sure device is powered off and unplugged from any power source.
Выберете то, что вам нужно
Remove the rubber foot with a Metal spudger
Remove 5 Phillip 2.4 x 5.7mm screws using a PH0 Phillips head screwdriver.
Remove 5 Phillips 2.8 x 5.0mm screws using a PH0 Phillips head screwdriver.
Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
Gently lift keyboard on the mouse pad side. Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
Remove the motherboard gently from the base of the laptop.
Disconnect the fastened cables from the motherboard by carefully pushing the cable's plastic edges using the metal Spudger.
Using the Phillips 00 Screw Driver. remove 4 screws from the heat sink.
Remove any adhesive tape. Detach the fan/heat sink.
2 участников успешно повторили данное руководство.
