Введение
In this guide we will be showing you how to replace the RAM on your HP Pavilion x360 m3-u103dx. This will help if your computer starts to slow down or if you are just looking for an upgrade. The RAM is located on the underside of the motherboard when coming from a keyboard first entry.
Выберете то, что вам нужно
Shut down the computer.
Disconnect the power and all external devices connected to the computer.
Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
Remove all of the screws located on the bottom of the laptop:
5 Phillips 2.4 x 5.7 mm screws
5 Phillips 2.0 x 5.0 mm screws
Turn the computer over onto its base, with the computer open and the keyboard facing upward.
Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
Инструмент, используемый на этом этапе:Heavy-Duty Spudger$4.99
Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
(You don't NEED to remove this shielding as you can remove the board with it still there.)
Remove the adhesive strip.
Lift the shield away from the base of the laptop.
Disconnect the ribbon cables attached to the system board (motherboard).
Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger.
Remove the system board (motherboard).
Using the Phillips 00 Screw Driver, remove 9 Phillips 2.0 x 4.7 mm screws with "M2L4" next to them.
Using the Phillips 00 Screw Driver, remove the silver screw.
Using a Heavy Duty Spudger, disconnect the black and red RTC battery cable on the left side of the system board (motherboard).
Gently lift the RAM out of the socket, retaining the 30 degree angle it rests at.
