Инструменты
Запчасти
Детали не указаны.
Locate the green RAM card and find the metal tabs securing the card.
Push outwards on the two tabs to release the card.
Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
Lift the cover from the right to remove it.
Use tweezers to detach the grey and black cables connected to the green WiFi card.
Remove the 8mm Philips screw located between the hard drive and the WiFi card.
Turn the laptop 90 degrees clockwise so you are facing the CD drive.
Unbend a paperclip and insert the end into the small hole by the eject button to cause the tray to pop out towards you.
Gently pull the tray away from the laptop and the rest of the optical drive will follow.
Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
Flip the laptop over and open the screen.
Push up on the four latches located at the top of the keyboard with the spudger to release them.
Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
Rotate the keyboard so that the bottom is visible.
With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
Pull the tab towards you to release the keyboard from the laptop.
Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
Rotate it so the display is on your right and the keyboard is on your left.
Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
The switch cover should easily separate from the laptop as you run the spudger through.
Close the lid and rotate the laptop so that the vents are facing you.
Unscrew the two 8mm Philips screws below the hinges.
Carefully rotate the laptop 90 degrees counter-clockwise and open the screen.
Pull on the black tab with the HP service sticker to unplug the display from the motherboard.
Using tweezers, remove the black cable from the hole leading to the WiFi enclosure.
Pull gently to remove the black and grey cables from the case.
Using tweezers, pull the black cable towards the display and through the hole in the casing.
Unscrew the two 8mm Philips screws that attach the hinge to the laptop's display.
Lift the screen upwards to detach it from the laptop.
Rotate the laptop 180 degrees so the vents are facing you.
Unscrew the four 3mm Philips screws below the vents.
Rotate the laptop 90 degrees counter-clockwise.
Unscrew the two 3mm Philips screws from the optical drive bay.
Flip the laptop over so it is face-up with the trackpad closest to you.
Locate the ribbon cable directly above the track pad.
Find the black latch at the end of the ribbon cable and unlatch it with a spudger to release it.
Find the ribbon cable on the LED board located at the top of the laptop.
You will notice that the ribbon cable is connected to two levels - you will be dealing with the one on the lower level.
Locate the white connector attached to a red and black cable to the right of the LED board.
Using tweezers, pull the white connector away from you.
Rotate the computer 90 degrees clockwise and insert the spudger at the seam above the card reader.
While lifting the front end of the top cover, slide the spudger across the seam.
When you have reached the firewire port, it should click open.
Locate the USB Module
Grip the yellow cable cover and pull it to the right to release it.
Unscrew and remove the five 4mm Philips screws marked with the white Phillips screw icon.
Using tweezers, remove the digital drive board cable - the cable set on the right with black, red, green, and white wires.
Using tweezers, remove the the rigth speaker cable - the cable set on the left with red and black wires - by pulling the white connector towards you.
Using tweezers, remove the left speaker cable by pulling the white connector towards you.
Remove the audio cable - the one with the yellow covering located at the bottom-right corner of the motherboard - by pulling the yellow covering towards you.
Rotate the laptop 180 degrees and locate the Bluetooth module at the bottom-left corner of the motherboard.
Using tweezers, remove the Bluetooth module’s white connector by pulling it away from you.
Using pliers, unscrew and remove the two bolts from both sides of the blue VGA connector.
Carefully flip the laptop face-down with the battery compartment facing you.
Using tweezers, remove the black and red cable from the RAM compartment by pulling on the white connector.
Flip the laptop face-up and turn it so that the drive labelled "hp usb digital drive" faces you.
Press the ridged space saver card above the "hp usb digital drive" label to eject and remove it.
Locate the PC card below the SD card reader.
Push the button to its left once to eject the button itself, then press it once again to remove the PC card.
Turn the computer 90 degrees counter-clockwise and clear all cables off of the motherboard.
Keeping the button pressed down, lift the motherboard up until the button pops out the top of the case.
Pull the right casing to the side to release the ports on the motherboard from it.
Lift the motherboard up until it releases from the bottom casing and remove it from the laptop.
Unscrew the two 4mm and one 2mm Phillips screws from the USB board.
Move the USB board out of the way and raise the right speaker unit up two inches.
Pull out the black cable running along the left side of the right speaker unit to remove it.
