Введение
Hard Drives are main components of your laptop. A bad hard drive can affect the speed of your computer. If you are experiencing slow loading times when opening programs or saved files, you should replace your hard drive.
Выберете то, что вам нужно
Flip the device over, so that the bottom cover is exposed.
Slide the black locking mechanism into its unlock position.
With the battery removed, the back cover can be taken off with your hand.
Use your Phillips 0 screwdriver to remove the four 2.5mm Phillips screws which hold the hard drive in place. You can see the 4 screws in the picture circled in red.
To disconnect the hard drive from the motherboard, pull the black tab as seen in the picture.
After removing the enclosure from the device, use your Phillips 0 screwdriver to remove four 3mm Phillips screws. There are two screws on each side of the hard drive enclosure.
Еще один человек закончил это руководство.
Один комментарий
Schritt 5 ist leider komplett falsch. Der SATA-Stecker muss von der Festplatte/SSD gezogen werden. Nicht irgendein Kabel vom Motherboard. Den Stecker zieht man einfacher von der HDD/SSD weg, wenn man zuerst Schritt #6 ausführt, dann ist die Metall-Lasche am Kopf des Steckers nicht mehr im Weg.
