Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
If you are having difficulties with your keyboard registering input, you may want to replace your keyboard.
Запчасти
Детали не указаны.
  1. Flip the device over, so that the bottom cover is exposed.
    • Flip the device over, so that the bottom cover is exposed.
    • Slide the black locking mechanism into its unlock position.
  2. After unlocking the mechanism, slide the battery out of its compartment.
    • After unlocking the mechanism, slide the battery out of its compartment.
  3. Remove the black bottom cover by using your fingernails or a thin flat tool.
    • Remove the black bottom cover by using your fingernails or a thin flat tool.
  4. Use the Phillips #0 screwdriver to remove three 5mm screws securing the keyboard. The screws to be removed are circled in red in the picture provided.
    • Use the Phillips #0 screwdriver to remove three 5mm screws securing the keyboard.
    • The screws to be removed are circled in red in the picture provided.
    • Make sure to place the screws somewhere safe like on top of a magnet.
  5. Flip the laptop so that they keyboard is facing you.
    • Flip the laptop so that they keyboard is facing you.
    • Use a thin and flat metal to carefully lift up the top side of the keyboard and separate it from the top cover.
  6. Now you will see the keyboard cable connector attached to a locking tab. Lift up the locking tab with a thin and flat screwdriver or your fingernail.
    • Now you will see the keyboard cable connector attached to a locking tab.
    • Lift up the locking tab with a thin and flat screwdriver or your fingernail.
    • The locking tab will open up at a 90 degree angle.
    • Pull the keyboard cable from the connector.
Заключение
Rosalia Olga Dupont Ayala
Участник с: 22.10.2018
210 Репутация
1 руководство автора
Команда
UC Davis, Team S7-G1, Lore Fall 2018 Участник UC Davis, Team S7-G1, Lore Fall 2018
UCD-LORE-F18S7G1
3 членов
Автор 4 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 17
За всё время: 320
