Введение
You will need to remove many parts of the computer. The key is to be careful when removing some parts of the computer.
Выберете то, что вам нужно
Shut down the computer.
Turn computer upside down so the base is facing upward.
Slide latch next to battery icon until battery pops up.
Pull the battery away from the computer until completely detached.
Position the computer so the front is towards you.
Remove two 5mm Phillips #1 screws
Slide the hard drive cover towards the empty battery spot and remove it.
Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
Slide cover toward empty battery area and remove it.
Disconnect the hard drive cable that is plugged in.
Lift the tab on the hard drive to pull it out of the computer.
Hard Drive is removed.
Remove one 5mm Phillips #1 Screw that is securing the optical drive.
With the nylon spudger push the optical drive until you can grab it.
Pull the optical drive all the way out, until removed.
Turn the computer upside down with the front towards you, and, remove the two rubber feet near the battery.
Remove 13 Phillips M2.0X7.0 screws.
Remove 6 Phillips M2.0X2.0 broad head screws.
Turn the computer over, and open the computer as far as possible without breaking it.
Release the top of the keyboard by lifting up and gently pull the top up until the whole keyboard is up.
Lift plastic cover to release the ZIF connector that is holding the keyboard in place. Then remove the keyboard.
Remove four 4mm Phillips #0 screws near the top of the keyboard area.
Lift top cover from the base and release the ZIF connector that the power button is connected to. The cover should now be removed.
Release 2 ZIF connectors where the touch pad cable and fingerprint reader are connected.
Take the top cover and put it upside down and remove one 3mm Phillips #1 screw.
Release ZIF connector on fingerprint reader and remove.
