Введение
The purpose of this guide is to teach reader to install a new LCD screen. If the current LCD screen is broken or cracked, this guide will help the reader to replace it with a new one.
Выберете то, что вам нужно
Use a Phillips #00 screwdriver to remove the two 4.7 mm screws in the bottom of the plastic casing.
Pull the bottom half of the inner camera out of the case by half an inch. This may be difficult.
Once the bottom of the inner camera is pulled out, pull the device out completely.
Using a Phillips #00 remove the four 4.40 mm screws that secure the LCD screen to the frame.
Allow the LCD screen to flip down. This will expose the electric strip that connects the screen to the camera.
Push the grey bar away from the white base. This will release the yellow electric strip and free the LCD screen from the camera.
Unplug the connected red and white wires. They will come out with the small white casing.
Flip camera so that the lens is facing away from you. You should be looking at the LCD screen.
Remove the bottom left LCD mounting frame screw. The screen should come loose after the screw is removed.
Remove the LCD screen from the camera. Make sure that the electric strip comes out with screen.
3 участников успешно повторили данное руководство.
Один комментарий
Thank for this very good job, I own this this camera so it is will be quite easy to fix it following your guide.
