Выберете то, что вам нужно
First, begin by removing the printer's hood.
Open the printer's mouth by simply pulling down on it; there are 2 mouth pieces that need to be pulled down.
Adjust the flap covering the scanner upward, as shown.
Remove the flap for the scanner. The flap is attached with two clips that can be dislodged by pulling lightly away from the printer.
Locate the three screws on top of the printer.
The orange circle shows a fourth screw located behind the power panel. Directions to remove this screw are in a later step.
Remove the three screws from the top of the printer with a T-9 screwdriver as shown.
To access and remove the fourth and final screw attaching the hood, the panel for the power button must be removed as follows:
Reach into the mouth of the printer and press on the small clip behind the power button. This allows the panel of the power button to be removed.
After pressing the clip, pull out the power button panel by pulling from right to left.
This step is easier with two people. Carefully have one person lift the hood of the printer 2-3 inches above where it was resting.
Remove the ribbon cables and wires attaching the motherboard (the only green PCB board) to the hood by gently pulling upward on them.
When all three cables are removed, lift the hood away from the printer and set it aside.
After being separated from the printer, the hood is ready to be disassembled.
Remove the only screw on the printer hood's underside, as shown. Use a T-9 screwdriver.
With the screw removed, separate the two pieces of the hood by lifting it vertically.
Carefully pull down the white ribbon cable through the top piece of the hood.
Set the piece of the hood down such that no stress is applied to the scanner as it is attached by ribbon cable.
Еще один человек закончил это руководство.
