Введение
If the scanner glass cracks or breaks, it will need to be replaced in it's entirety. The glass is visible when you open the top of the printer so you will be able to tell if it needs replacement without taking the printer apart.
Выберете то, что вам нужно
Use the blue plastic opening tool to pry the trim pieces all the way around the printer.
Loosen the pieces around the edges before pulling to remove from the printer.
Pull the (4) trim pieces off and set them aside.
Using the blue plastic opening tool, pull from the middle and then slide back to remove the side panels.
The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
Both clips will come unattached and you can set the scanner flap aside.
Еще один человек закончил это руководство.
