Инструменты
Запчасти
Детали не указаны.
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
Firmly pull the the back of the side panel until it separates from the body of the printer.
Rotate the side panel upwards while pulling it towards yourself to remove the panel.
Rotate the printer 90 degrees clockwise.
Grasp the paper tray and rotate it down.
Insert your fingers into the slot in the printer door and pull to rotate the gate down.
Remove the two T10 12 mm Torx screws.
Grasp both sides of the side panel and pull it forward to remove the panel.
Rotate the printer 90 degrees counter clockwise.
Lift the scanner lid to expose the scanner glass.
Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
Remove the front panel by grasping its front and pulling away from the printer.
Remove the cable connecting the top panel of the printer to the power button assembly.
Set aside the printer body.
Remove the three T10 12 mm Torx screws from the back of control panel circuit board.
Using both hands, carefully lift the control panel circuit board from the top panel of the printer.
3 участников успешно повторили данное руководство.
