Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
Firmly pull the the back of the side panel until it separates from the body of the printer.
Rotate the side panel upwards while pulling it towards yourself to remove the panel.
Rotate the printer 90 degrees clockwise.
Grasp the paper tray and rotate it down.
Insert your fingers into the slot in the printer door and pull to rotate the gate down.
Remove the two T10 12 mm Torx screws.
Grasp both sides of the side panel and pull it forward to remove the panel.
Rotate the printer 90 degrees counter clockwise.
Lift the scanner lid to expose the scanner glass.
Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
Remove the front panel by grasping its front and pulling away from the printer.
Remove the cable connecting the top panel of the printer to the power button assembly.
Carefully lift the top panel of the printer away from the printer body.
Set aside the top panel of the printer.
Remove the two T10 12 mm Torx screws from the top front of the printer
Rotate the Printer 90 degrees counter clockwise.
Remove the scanner cable from the main circuit board.
Using both hands, lift the scanner tray from the body of the printer.
Remove the power button circuit board from the support frame by pinching the left side, and pulling forward and to the left simultaneously.
Push up on the tab holding the secondary control circuit board with the spudger and pull it forward to remove it.
Lift the support frame off of the printer body with both hands.
Remove the printer door and paper tray by putting them in the closed position and not laying flat then rotating them upwards lift the left side up.
Remove both of the ink cartridges by grabbing the front of the ink cartridge and pulling down.
Remove the T10 6 mm Torx screw on the left side of the track assembly.
Remove the T10 12 mm Torx screw on the left side of the track assembly.
Gently push the ink cartridge carriage to the left side of the printer.
Remove the two T10 6 mm Torx screws.
Remove the cable connecting the ink cartridge carriage to the main circuit board.
Carefully remove the connector holding the drive motor wires to the main circuit board.
Slide the ink cartridge carriage all the way to the right side of the printer.
Using both hands, carefully lift the ink cartridge track off of the main body of the printer.
Set aside the printer body
Unhook the encoding strip by pinching it on the right side and pulling away from the center of the ink cartridge track.
Grasp the metal tab holding the encoding strip and pull it away from the track while pulling it up.
Without releasing the metal tab, pull the encoding strip through the ink cartridge carriage. The encoding strip should slide out smoothly.
4 участников успешно повторили данное руководство.
