Shut the device off.
  • Shut the device off.
  • Lift the top cover of the scanner.
  • Carefully, pry the plastic frame surrounding the glass away from the printer hood using a plastic prying tool.
  • Pull the frame out.
Добавить комментарий
Unscrew the two screws that fasten the frame to the printer hood. Use a T10 screwdriver
  • Unscrew the two screws that fasten the frame to the printer hood. Use a T10 screwdriver
  • Pushing the clip behind the cover piece in, pull the cover piece outwards.
  • Remove the two screws on the front of the printer with a T10 screwdriver.
    • The first is inside the power button panel space and the second is across the printer slider.
  • Pull the circuit board from the power button panel space.
  • Unplug the small ribbon cable from the circuit board.
  • Pull the memory card reader's circuit board out of its slot.
  • Detach the rainbow connector from the back of the circuit board.
  • Press the clip directly behind the TouchSmart panel and pull the panel up.
  • Disconnect the ribbon cable from the TouchSmart panel. This detaches the panel from the printer body.
  • Do not hesitate to use force to remove the TouchSmart panel.
  • Grip the printer hood and pull upward.
  • With the top half of the printer separated, lift the upper section with the scanner glass away from the lower section of the printer.
  • With the glass facing upwards, remove the screw holding the glass in place.
  • Lift the glass up and away from the printer.
  • Handle glass with care.
  • Replace the broken glass piece with the replacement glass
Заключение
2 участников успешно повторили данное руководство.
garrett hall
Участник с: 26.09.2012
49 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 2-11, Propen Fall 2012 Member of Cal Poly, Team 2-11, Propen Fall 2012
CPSU-PROPEN-F12S2G11
4 членов
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 17
За всё время: 2,327
