Lift the top cover of the scanner. Using a small plastic prying tool, carefully pry the plastic frame surrounding the glass from the printer hood. Pry the side piece from the printer hood.
  • Lift the top cover of the scanner.
  • Using a small plastic prying tool, carefully pry the plastic frame surrounding the glass from the printer hood.
  • Pry the side piece from the printer hood.
  • Pull the frame out.
Добавить комментарий
Using a T10 screwdriver, unscrew the two screws that fasten the frame to the printer hood.
  • Using a T10 screwdriver, unscrew the two screws that fasten the frame to the printer hood.
Pushing the clip behind the cover piece in, pull the cover piece outwards. Pushing the clip behind the cover piece in, pull the cover piece outwards.
  • Pushing the clip behind the cover piece in, pull the cover piece outwards.
Remove the two screws on the front of the printer. The first is inside the power button panel space and the second is across the printer slider. Unscrew them with a T10 screwdriver.
  • Remove the two screws on the front of the printer.
    • The first is inside the power button panel space and the second is across the printer slider. Unscrew them with a T10 screwdriver.
Pull the circuit board from the power button panel space.
  • Pull the circuit board from the power button panel space.
  • Unplug the small ribbon cable from the circuit board.
Pull the memory card reader's circuit board out of its slot. Detach the rainbow connector from the back of the circuit board.
  • Pull the memory card reader's circuit board out of its slot.
  • Detach the rainbow connector from the back of the circuit board.
Press the clip directly behind the TouchSmart panel and pull the panel up. Disconnect the ribbon cable from the TouchSmart panel. This detaches the panel from the printer body.
  • Press the clip directly behind the TouchSmart panel and pull the panel up.
  • Disconnect the ribbon cable from the TouchSmart panel. This detaches the panel from the printer body.
  • Do not hesitate to use force to remove the TouchSmart panel.
Gripping the printer hood, pull upward.
  • Gripping the printer hood, pull upward.
Lift the scanning lid from the lower portion of the printer hood. Lift the scanning lid from the lower portion of the printer hood.
  • Lift the scanning lid from the lower portion of the printer hood.
Remove torx screw on bottom of assembly in corner near touchsmart screen space.
Jeff - Ответить
Leaving the ribbon connected, lift the sliding scanner off the track. Pull the ribbon cable out of the slot on the scanner circuit board.
  • Leaving the ribbon connected, lift the sliding scanner off the track.
  • Pull the ribbon cable out of the slot on the scanner circuit board.
  • Insert the scanning piece into the rolling track.
Заключение
To reassemble the sliding scan piece, follow these instructions in reverse order.
Renee Lamb
208 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 2-11, Propen Fall 2012 Member of Cal Poly, Team 2-11, Propen Fall 2012
CPSU-PROPEN-F12S2G11
4 членов
Автор 6 руководств
Один комментарий
Where can i buy the scaning piece? Im from Spain.
Bogdan Cosmin - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 5
За всё время: 1,193
