Введение
Repacing an old heat sink will allow for better cooling of the processor. Making your computer run smother and last longer.
Выберете то, что вам нужно
Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
Slightly push up while lifting up on the power button panel to release the panel.
Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
Carefully (holding both sides of the keyboard), push up and lift slightly.
Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
Use the black spudger to lift the black latch holding the keyboard ribbon cable.
Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
Unscrew the five silver (2.5 mm Phillips) screws that are holding the panel in.
Unscrew the two black (3.0 mm Phillips) screws that are holding the panel in.
Disconnect the red, black, and blue ribbon cable connector using the black spudger.
Unscrew the four (2.5 mm Phillips) screws holding the processor heat sink in (located near the center of the laptop)
Lift slightly on the main component of the heat sink and slowly pull in towards the center (to your right) to free the heat sink.
Еще один человек закончил это руководство.
