Введение
Broken speakers can be very annoying. Replacing the old speakers can bring new life to your beats.
Выберете то, что вам нужно
Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
Slightly push up while lifting up on the power button panel to release the panel.
Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
Carefully (holding both sides of the keyboard), push up and lift slightly.
Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
Use the black spudger to lift the black latch holding the keyboard ribbon cable.
Use the black spudger tool to lift the white, black, and red ribbon cable connector up so that it is disconnected.
Unscrew the two (2.5 mm Phillips) screws (located on the upper most part of the computer) holding the speakers in.
Еще один человек закончил это руководство.
