Введение
Your computer’s service panel may become damaged after prolonged use or age. One of the ways you can fix this is by replacing the panel itself.
Slide the two release latches that were mentioned in the battery removal process to release the service panel.
Slide the service panel toward you using your thumbs.
Lift it to remove the panel and reveal inner components of the computer.
Еще один человек закончил это руководство.
