HP Slate 7 4601 Motherboard Replacement
Выберете то, что вам нужно
  1. HP Slate 7 4601 Motherboard Replacement, Battery: шаг 1, изображение 1 из 2 HP Slate 7 4601 Motherboard Replacement, Battery: шаг 1, изображение 2 из 2
    • Begin your replacement by using a T3 or T4 Torx screwdriver.
    • Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
    On the HP 10 Plus 2201 there are no head screws. I used the spudger to 'carefully' separate the case. There are little snaps on the inside of case that will separate with little pressure on spudger.
    RB Richter - Ответить
    I used these directions to replace HP Plus 10 2201 battery. I bypassed speaker installation.
  2. HP Slate 7 4601 Motherboard Replacement: шаг 2, изображение 1 из 2 HP Slate 7 4601 Motherboard Replacement: шаг 2, изображение 2 из 2
    • With the pointed end of the spudger, remove the thin metal band.
    • It is easiest to remove the metal band through the headphone opening.
    On HP 10 Plus 2201 there is no metal band. The case simply unsnaps apart.
  3. HP Slate 7 4601 Motherboard Replacement: шаг 3, изображение 1 из 2 HP Slate 7 4601 Motherboard Replacement: шаг 3, изображение 2 из 2
    • Using the flat end of the spudger, pry back the rear plastic cover.
    • As you work your way around the edge, several "pop" noises will be made. These noises are caused by the plastic clips coming undone.
    This is basically how I opened my HP 10 Plus 2201. "Using the flat end of the spudger, pry back (apart) the rear plastic cover from tablet.
  4. HP Slate 7 4601 Motherboard Replacement: шаг 4, изображение 1 из 1
    • Remove the rear cover.
  5. HP Slate 7 4601 Motherboard Replacement: шаг 5, изображение 1 из 1
    • Locate and remove the yellow tape covering the red and white speaker wires.
    The inside of my HP 10 Plus 2210 looks similar but not exactly as this illustration
    The battery connections weren't the plug in type. The three battery battery wires (red, white, & black) were soldered into place,
  6. HP Slate 7 4601 Motherboard Replacement: шаг 6, изображение 1 из 2 HP Slate 7 4601 Motherboard Replacement: шаг 6, изображение 2 из 2
    • Using the pointed end of the spudger, push both sides of the speaker wire connector out of its base.
    • Push the same amount on both sides of the connector to avoid jamming or twisting its metal pins.
    • Do not yank or pull on the speaker wires, since they are fragile. Only push on the white connector.
    Do not pull on wires. Never force anything.
    note the route of the speaker cables round the battery
    Alan Boddey - Ответить
  7. HP Slate 7 4601 Motherboard Replacement: шаг 7, изображение 1 из 1
    • Gently pull back the foil covering the gold charging port ribbon.
    Hpcom Support Helps HP Printer users to download and install All Hp Printers drivers. We also provide all possible solutions to fix hp Printer problems. If you face any issue in install Hp printer driver or having other problems with the hp Printer, you can follow our 100 % working solutions. In case you can’t able to continue printing, then feel free to contact us. We are happy to serve you.
    hpcom us - Ответить
  8. HP Slate 7 4601 Motherboard Replacement: шаг 8, изображение 1 из 2 HP Slate 7 4601 Motherboard Replacement: шаг 8, изображение 2 из 2
    • Using the flat end of the spudger, lift up the black panel covering the charging port connector.
    • Gently slide the charging port ribbon out from its housing.
    • It may be easier to use the pointed end of the spudger than your fingers.
  9. HP Slate 7 4601 Motherboard Replacement: шаг 9, изображение 1 из 1
    • Lift gold charging strip away from the battery.
  10. HP Slate 7 4601 Motherboard Replacement: шаг 10, изображение 1 из 2 HP Slate 7 4601 Motherboard Replacement: шаг 10, изображение 2 из 2
    • Push the white battery connector out of its housing using the pointed end of the spudger.
  11. HP Slate 7 4601 Motherboard Replacement: шаг 11, изображение 1 из 1
    • Using the #00 Phillips Head screwdriver, remove the 5 screws holding the battery in place.
    • The four 1.75mm x 3mm silver Phillips Head screws circled in red are interchangeable.
    • The black 1.75mm x 4mm Phillips Head screw must go back to the same spot during reassembly.
  12. HP Slate 7 4601 Motherboard Replacement: шаг 12, изображение 1 из 1
    • Lift battery out of its place and set aside.
  13. HP Slate 7 4601 Motherboard Replacement, Motherboard: шаг 13, изображение 1 из 2 HP Slate 7 4601 Motherboard Replacement, Motherboard: шаг 13, изображение 2 из 2
    • Disconnect the LCD screen ribbon by lifting up the black panel with the flat end of a spudger and sliding the gold strip out.
    • When reconnecting the LCD connector ribbon, make sure that it's pushed in all the way. If it isn't, there will be horizontal lines when you power the tablet on.
  14. HP Slate 7 4601 Motherboard Replacement: шаг 14, изображение 1 из 2 HP Slate 7 4601 Motherboard Replacement: шаг 14, изображение 2 из 2
    • Likewise, disconnect the square radio chip ribbon by lifting up the black panel with a spudger and sliding the gold strip out.
  15. HP Slate 7 4601 Motherboard Replacement: шаг 15, изображение 1 из 2 HP Slate 7 4601 Motherboard Replacement: шаг 15, изображение 2 из 2
    • You will be using a #00 Phillips Head screwdriver to free the motherboard.
    • Remove the six 1.75mm x 3mm Phillips Head screws holding the motherboard to the screen.
  16. HP Slate 7 4601 Motherboard Replacement: шаг 16, изображение 1 из 2 HP Slate 7 4601 Motherboard Replacement: шаг 16, изображение 2 из 2
    • Using your hand, lift up the silver tape from the copper plate.
    • Lift the motherboard out of the device.
    • You may need to wiggle and work the motherboard to get it released from the device
    You will need to transfer the camera from the old motherboard to the new.
    Gently disconnect the connector marked “BYD”.
    Gently press down on the camera lens in order to release ir from the board and feed the connector through the motherboard by turning the connector in a diagonal position in order to feed it through the motherboard.
    rmeischner@comcast.net - Ответить
Заключение
4 участников успешно повторили данное руководство.
Davis Muxlow
Участник с: 04/14/14
242 Репутация
1 руководство автора
Команда
Cal Poly, Team 13-30, Maness Spring 2014 Участник Cal Poly, Team 13-30, Maness Spring 2014
CPSU-MANESS-S14S13G30
3 членов
Автор 8 руководств
Один комментарий
We have 7 inch Hp tablet please replace motherboard sir
Sushmitha - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 17
За всё время: 3,773
