Выберете то, что вам нужно
Turn off the tablet and disconnect the power and all external devices from the tablet.
Position the tablet with the display panel down and the right side toward you.
Carefully insert a plastic opening tool between the tablet cover and display panel assembly, separating the two components. The first insertion point should be between the power button and the volume buttons.
Slide the tool around the perimeter of the tablet until the edge of the cover is completely separated from the display panel assembly.
Disconnect the battery cables from the system board by desoldering them. See iFixit guide on how to solder.
Insert a nylon spudger between the battery and the display panel assembly. Carefully pry the battery up and remove it from its place.
Use the tweezers to remove the black foam stickers from the rear facing camera to expose the wiring.
Use tweezers to pull the wire out from the connector. Pull away from the connector, parallel to the tablet.
