Введение
Overall the step by step guide will provide you with information on how to go about replacing an antenna on the HP Slate 8 Pro if wifi is not working properly or signal is low.
Запчасти
Никакие детали не требуются.
  1. Use plastic tool to remove the back cover.
    • Use plastic tool to remove the back cover.
  2. Release the Wi-Fi antenna cable from the routing clips and channel from the main board.
    • Release the Wi-Fi antenna cable from the routing clips and channel from the main board.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Detach the Wi-Fi antenna from the main board.
    • Detach the Wi-Fi antenna from the main board.
  5. Detach the Wi-Fi antenna transceiver from the display panel assembly that is attached with adhesive.
    • Detach the Wi-Fi antenna transceiver from the display panel assembly that is attached with adhesive.
Заключение
Jose Revelo
Участник с: 23.09.2014
305 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 9-4, Blackwell Fall 2014 Member of USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
4 членов
Автор 10 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 483
