Введение
This guide will give you step-by-step instructions on how to remove and replace a faulty motherboard. Make sure you have a clean, dry, uncluttered, and roomy work space that has good lighting before you start. Also, make sure that your motherboard actually needs to be replaced by consulting our troubleshooting guide troubleshooting guide.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Turn the computer upside down.
Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
Use an opening tool to pry up and loosen the back case from the laptop.
Remove the back case.
Peel off the adhesive on the left side of the battery holding the speaker wire down.
Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
Carefully unplug the battery by pulling the connector towards the battery.
Remove the battery.
Remove the two 2mm Phillips #00 screws from the fan.
Disconnect the fan from the motherboard.
Using a plastic opening tool, disconnect the antenna wires from the WiFi card.
Remove the single Phillips #00 screw from the WiFi card.
Slide the module up until it is completely removed.
Use a plastic opening tool to flip up the retaining flap on the ribbon cable ZIF socket.
Pull the ribbon cable out of the ZIF connector.
Using two plastic opening tools, Disconnect the right speaker cable from the motherboard.
Identify the ZIF connector that connects the keyboard to the back light as shown in the image.
Using a plastic opening tool, lift the locking bar on the ZIF connector that connects the keyboard back light to the motherboard.
Gently pull the cable out.
Gently peel back the tape on the locking bar of the keyboard connector.
Using a plastic opening tool, pull up on the locking bar.
Identify the touch pad ZIF cable as shown in the image.
Using a plastic opening tool, Gently lift up the locking bar on the touch pad ZIF.
Gently slide the cable out.
Using a plastic opening tool, Lift the locking bar on the card reader ZIF connector.
Using a plastic opening tool, Lift the locking bar on the display connector.
Grip the black tape and pull up to unplug.
Remove the 3.5mm Phillips #00 screw securing the motherboard to the top cover.
Remove the 2mm Phillips #00 screw securing the motherboard to the top cover.
7 участников успешно повторили данное руководство.
3 Комментариев
Thanks good instructions once I source a replacement board I will apply you're method. I live near Barcelona Spain any ideas on sourcing a new board??
Thanks, it’s easy with your explications
Merci pour vos explications très détaillés qui m'ont permis de changer la carte mère d'un hp spectre x360-13 sans trop de difficultées le 13 juillet 2020.
J'ai tout particuliérement apprécié les détails pour ouvrir les différents connecteurs.
Seule difficulté était l'ouverture de la vis de fixation de la carte wifi, qui état extrêmement ferme.
Une fois la nouvelle carte mère installé le portable a démarré sans aucune autre intervention.
J'ai horreur de jetter des équipements dont seulement un élément est défectueux et je suis donc très reconnaissant de votre publication.
Un grand Merci
Albrect E.
Chantilly France
