Введение
This guide will give you step-by-step instructions on how to remove your touchpad. Make sure you have a clean, dry, uncluttered, and roomy work space that has good lighting before you start. Also, make sure that your touchpad actually needs to be replaced by consulting our troubleshooting guide.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Turn the computer upside down.
Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
Use an opening tool to pry up and loosen the back case from the laptop.
Remove the back case.
Peel off the adhesive on the left side of the battery holding the speaker wire down.
Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
Carefully unplug the battery by pulling the connector towards the battery.
Remove the battery.
Using a plastic opening tool, lift the locking bar on the trackpad ZIF connector.
Gently pull the cable out.
Using the PH00 Screwdriver, remove the five 2.0 mm screws indicated in the picture.
Using a plastic opening tool, carefully lift up on the lower center metal piece of the touchpad.
Using both hands, gently lift up on the touchpad until it is completely removed.
2 участников успешно повторили данное руководство.
