Введение
This guide will instruct you on how to remove and replace the battery. If the battery doesn’t hold a charge a replacement may be necessary.
Выберете то, что вам нужно
Turn off and unplug the laptop.
Flip the laptop so that the backplate is exposed.
Инструмент, используемый на этом этапе:Tweezers$4.99
Disconnect the 3 wires connected to the battery.
Lift the battery off of the alignment pins on the top cover and remove it from the device.
Почти готово!
Заключение
