Введение
If your HP Spectre x360 13-ac023dx laptop cannot connect to the wifi after troubleshooting the problem, use this guide to replace the wifi card.
Выберете то, что вам нужно
Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
Then, carefully lift the battery off with the iFixit opening tool.
Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
Once the screw is removed, raise the WiFi card and slide it out from the motherboard.
