Введение
This guide will instruct you on how to remove and replace the battery. Battery replacement may be necessary if the battery is not able to hold a charge.
Выберете то, что вам нужно
Turn off and unplug the laptop.
Flip over the laptop so that the bottom backplate is exposed.
Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
Use the same screwdriver to remove the two 7 mm screws.
Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
Carefully work your way around the cover's edges to pop it off completely.
With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
With the screws removed, disconnect the 3 wires connected to the battery.
4 участников успешно повторили данное руководство.
