Введение
This guide will walk you through the step-by-step process of safely and efficiently replacing the battery in your HP Spectre x360 15-eb0xxx laptop. Make sure to power off your laptop and disconnect it from any power source before starting.
Выберете то, что вам нужно
Start from one corner and carefully pry up the bezel.
Lift the bezel away and place it aside once it has been loosened.
Remove the six Phillips M2.0×mm screws using the Phillips #000 Screwdriver.
Remove the two Torx5 M2.0×3.8mm screws using the T5 Torx Screwdriver.
Use a guitar pick or another tool to pry up the backplate from the laptop.
Remove the backplate from the laptop.
Remove the 6 Phillips M2.0×4.2mm screws next to the battery using a Phillips #00 screwdriver.
After locating the screws.
Now locating the power supply
Which is shown in the picture in the highlighted box.
The power supply can be loosened up with a pick.
Now it can be easily pulled out with your fingernails as shown in the picture.
On the right and the left side of the battery
You will encounter cables that will be under a hook from both sides.
To remove the battery they can be unhooked like shown in the pick
Use a pick or not a card to losen battery
Stick pick right in the middle in between battery and computer
When pulling the battery carefully at an angle
Remove battery
Один комментарий
is it possible to upgrade RAM on "hp spectre x360 convertible 15-eb0xxx " The information everywhere is confusing. By using pc audit tool, it seems I can, but everyone on internet says i cannot!
