HP Split 13-r010dx Front and Back Panel Replacement
Выберете то, что вам нужно
  1. HP Split 13-r010dx Front and Back Panel Replacement, Front and Back Panel: шаг 1, изображение 1 из 2 HP Split 13-r010dx Front and Back Panel Replacement, Front and Back Panel: шаг 1, изображение 2 из 2
    • Locate the four screws at the bottom of the device. (Note that the keyboard attachment is missing from this device.)
    • Use a Philips head #0 screwdriver to remove each of the screws (Size: 4mm)
  2. HP Split 13-r010dx Front and Back Panel Replacement: шаг 2, изображение 1 из 2 HP Split 13-r010dx Front and Back Panel Replacement: шаг 2, изображение 2 из 2
    • Gently wedge the plastic opening tool in between where the display and back panel meet.
    • Slowly and gently apply force to the plastic opening tool in a downwards motion to loosen the front panel from the back panel.
    • Rotate the device so that the side is facing up and repeat the previous step for the sides.
    • Do NOT attempt to wedge the plastic opening tool on the bottom . Once the sides and top are loose you are ready to continue to the next step.
  3. HP Split 13-r010dx Front and Back Panel Replacement: шаг 3, изображение 1 из 1
    • Gently and slowly pull the front and back panel away from each other (in opposite directions). ( Pulling them apart will not separate the two panels)
    • Only separate the panels by a few inches from each other so that there is room to separate the front and back panel in the next step. Proceed to the next step.
  4. HP Split 13-r010dx Front and Back Panel Replacement: шаг 4, изображение 1 из 1
    • Hold the back panel firmly and pull the front panel upwards to completely separate the front panel from the back panel.
    • The device is now ready to be repaired or replacements installed.
Заключение
Kyle Jaeger
Участник с: 09/25/17
209 Репутация
1 руководство автора
Команда
University of North Texas, Team S2-G1, Thompson Fall 2017 Участник University of North Texas, Team S2-G1, Thompson Fall 2017
UNT-THOMPSON-F17S2G1
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 429
