Введение
This is a step by step guide on replacing an old or damaged battery of an HP Split x2 with a new battery unit.
Выберете то, что вам нужно
Separate the tablet from the keyboard by pushing the slider to the left and lifting the tablet from the keyboard.
Use a plastic opening tool to pry the tabs on the top, left and right sides of the tablet.
Flip up the retaining flap with either a spudger or your fingertips.
Disconnect the ribbon cable by gently pulling on it.
Disconnect the sliding connector with the pointed tip of the spudger and gently remove the cable.
4 участников успешно повторили данное руководство.
5 Комментариев
Does the HP split have 2 batteries? One in screen part & 1 in keyboard part?
can you email the battery part number and where I can buy in the US ?
my email is leprince1@gmail.com
I have a hp split just like this one i actually preessed down hard on the power bottom because it wouldnt turn on so the power bottom is pushed in so i really can’t power it up .. But before that my computer would not charge sometimes
can you please try an point me to the right direction on this issue
please email me at
galvanmichelle7@gmail.com
I own a split x2, but my screen is broken and my keyboard stopped working… is there a way this can be fixed??
The screen is working, however the keyboard portion is not powering up . The light is not coming on when the power supply is placed in it and the bottom of the keyboard gets very hot once plugged in. Help needed.
