Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This is a step by step guide on replacing an old or damaged battery of an HP Split x2 with a new battery unit.
Запчасти
Детали не указаны.
  1. Opening the device voids the manufacturer warranty.
    • Opening the device voids the manufacturer warranty.
    • Power down the HP Split x2 before beginning the repair
    • Separate the tablet from the keyboard by pushing the slider to the left and lifting the tablet from the keyboard.
  2. Remove the four white caps on the bottom edge of the tablet. Use a tweezer to grasp white caps. The white caps are easily lost. Store them in a secure place.
    • Remove the four white caps on the bottom edge of the tablet.
    • Use a tweezer to grasp white caps.
    • The white caps are easily lost. Store them in a secure place.
  3. Use a Phillips #000 screwdriver to remove the four 3mm screws.
    • Use a Phillips #000 screwdriver to remove the four 3mm screws.
  4. Use a plastic opening tool to pry the tabs on the top, left and right sides of the tablet. Only the top and sides have tabs. Remove all tabs before lifting screen.
    • Use a plastic opening tool to pry the tabs on the top, left and right sides of the tablet.
    • Only the top and sides have tabs. Remove all tabs before lifting screen.
  5. Separate the cover and  the screen. Gently lift the screen out of the cover.
    • Separate the cover and the screen.
    • Gently lift the screen out of the cover.
  6. Remove black stickers Remove black stickers Remove black stickers
    • Remove black stickers
  7. Pull on the blue ribbon to disconnect the cable Disconnect both ends of the cable Disconnect both ends of the cable
    • Pull on the blue ribbon to disconnect the cable
    • Disconnect both ends of the cable
  8. Flip up the retaining flap with either a spudger or your fingertips. Disconnect the ribbon cable by gently pulling on it. Disconnect the sliding connector with the pointed tip of the spudger and gently remove the cable.
    • Flip up the retaining flap with either a spudger or your fingertips.
    • Disconnect the ribbon cable by gently pulling on it.
    • Disconnect the sliding connector with the pointed tip of the spudger and gently remove the cable.
  9. Remove all eight 3mm Phillips screws using a J1 screw head. Remove all eight 3mm Phillips screws using a J1 screw head. Remove all eight 3mm Phillips screws using a J1 screw head.
    • Remove all eight 3mm Phillips screws using a J1 screw head.
  10. Gently lift up the battery as a whole Make sure the battery is free to move on both ends.
    • Gently lift up the battery as a whole
    • Make sure the battery is free to move on both ends.
    • Battery has two cells connected by a bridge making it a unit.
Заключение
4 участников успешно повторили данное руководство.
Alvaro Esperanca
Участник с: 04.03.2017
239 Репутация
1 руководство автора
Команда
IUPUI, Team S6-G6, Wilson Spring 2017 Участник IUPUI, Team S6-G6, Wilson Spring 2017
IUPUI-WILSON-S17S6G6
4 членов
Автор 2 руководств
Комментариев: 5
Does the HP split have 2 batteries? One in screen part & 1 in keyboard part?
Genny Gallup - Ответить
can you email the battery part number and where I can buy in the US ?
my email is leprince1@gmail.com
Imran Karram - Ответить
I have a hp split just like this one i actually preessed down hard on the power bottom because it wouldnt turn on so the power bottom is pushed in so i really can’t power it up .. But before that my computer would not charge sometimes
can you please try an point me to the right direction on this issue
please email me at
galvanmichelle7@gmail.com
Michelle Marie - Ответить
I own a split x2, but my screen is broken and my keyboard stopped working… is there a way this can be fixed??
Dosunmu Adelani - Ответить
The screen is working, however the keyboard portion is not powering up . The light is not coming on when the power supply is placed in it and the bottom of the keyboard gets very hot once plugged in. Help needed.
LENNY - UNA PHILERT - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 20
За последние 30 дней: 122
За всё время: 9,806
