Введение
This guide will show how to remove the malfunctioning flash circuit board in the HP Sprocket 2-in-1 device. The guide uses tools from the iFixit Pro Tech Tool Kit. This guide contains steps which involve removal of very delicate ribbon cables, be sure to avoid tugging and pulling as they can easily tare and cause the need for replacement.
Выберете то, что вам нужно
Using the Jimmy, slowly pry open the outer edge of the remaining white plastic on the back.
Remove the plastic from the device once it lifts out freely.
Remove two 2.5mm JIS #00 located on the small circuit board in view.
Use the Jimmy to remove the board after the screws have been removed.
Remove two 2.5mm JIS #00 screws from the translucent plastic bracket.
Remove the translucent plastic bracket by hand.
Use the iFixit opening tool to slowly work between the white and beige casing around the device.
Flip the device over and seperate the white casing from the rest of the device.
Using a Japanese Industrial Standard (J) screwdriver (J00 bit), remove three 2.5mm screws connecting the flash circuit board to the housing.
