HP Star Wars Special Edition 15-an051dx Battery Replacement
  1. HP Star Wars Special Edition 15-an051dx Battery Replacement, Battery: шаг 1, изображение 1 из 3 HP Star Wars Special Edition 15-an051dx Battery Replacement, Battery: шаг 1, изображение 2 из 3 HP Star Wars Special Edition 15-an051dx Battery Replacement, Battery: шаг 1, изображение 3 из 3
    • Make sure the device is fully powered down and unplugged from external power.
    • Close the device and turn it over so it will be on its back.
  2. HP Star Wars Special Edition 15-an051dx Battery Replacement: шаг 2, изображение 1 из 3 HP Star Wars Special Edition 15-an051dx Battery Replacement: шаг 2, изображение 2 из 3 HP Star Wars Special Edition 15-an051dx Battery Replacement: шаг 2, изображение 3 из 3
    • In the red is the battery and the battery's holding/locking latches.
    • Slide the latches in the direction the arrows face. This will unlock and release the battery.
    • Set the old battery aside or dispose of properly by following the manufacturers instructions written on the battery or check online of battery disposal services.
  3. HP Star Wars Special Edition 15-an051dx Battery Replacement: шаг 3, изображение 1 из 3 HP Star Wars Special Edition 15-an051dx Battery Replacement: шаг 3, изображение 2 из 3 HP Star Wars Special Edition 15-an051dx Battery Replacement: шаг 3, изображение 3 из 3
    • Check the battery port on your device and make sure it is clear of debris and pins are not bent or damaged.
    • Install the new battery into the port and press down gently.
    • Make sure it latches on to its locking clip.
    • Once installed and you have followed the battery manufacturer's instructions, turn your device on to its upright position and boot your device.
Заключение
Device should be working as usual with the new battery.
Еще один человек закончил это руководство.
Fernando Mendez
Участник с: 08/25/22
643 Репутация
Автор 5 руководств
Команду
Gateway, Team 1-2, Pee Fall 2022 Участник Gateway, Team 1-2, Pee Fall 2022
GCC-PEE-F22S1G2
4 членов
Автор 5 руководств
1Комментарий к руководству
Altho this a simple fix some people still have a hard time removing the battery so thank you very much
RETRO GAMEHEAD - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 9
За последние 30 дней: 20
За всё время: 349
