HP Stream 11-d010nr Keyboard Replacement
Выберете то, что вам нужно
  1. HP Stream 11-d010nr Keyboard Replacement, Keyboard: шаг 1, изображение 1 из 2 HP Stream 11-d010nr Keyboard Replacement, Keyboard: шаг 1, изображение 2 из 2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d010nr Keyboard Replacement: шаг 2, изображение 1 из 1
    • Remove the eleven 5.6 mm Phillips #1 screws.
  3. HP Stream 11-d010nr Keyboard Replacement: шаг 3, изображение 1 из 2 HP Stream 11-d010nr Keyboard Replacement: шаг 3, изображение 2 из 2
    • Using an iFixit opening tool, pry open the case to separate the keyboard from the main body.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
  4. HP Stream 11-d010nr Keyboard Replacement: шаг 4, изображение 1 из 1
    • Slowly lift the keyboard as there are multiple ribbon cables that could easily be damaged if lifted with force.
    • Carefully lift the keyboard and locate the three ribbon cables connecting the main body of the laptop to the keyboard.
  5. HP Stream 11-d010nr Keyboard Replacement: шаг 5, изображение 1 из 3 HP Stream 11-d010nr Keyboard Replacement: шаг 5, изображение 2 из 3 HP Stream 11-d010nr Keyboard Replacement: шаг 5, изображение 3 из 3
    • Using your fingernail, lift the flaps on the ZIF connectors that are securing the three ribbon cables.
    • Carefully disconnect the three ribbon cables.
  6. HP Stream 11-d010nr Keyboard Replacement: шаг 6, изображение 1 из 1
    • Lift the keyboard out of the laptop to remove it from the device.
Заключение
Еще один человек закончил это руководство.
Josh Corrigan
Участник с: 01/24/19
341 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S1-G3, White Winter 2019 Участник Cal Poly, Team S1-G3, White Winter 2019
CPSU-WHITE-W19S1G3
4 членов
Автор 11 руководств
2 Комментариев
I feel like the 5-10 minutes estimated time is way too short for this repair (however, I have not done this, and may be wrong).
Constantin Legras - Ответить
There will definitely be variation depending on each individual but our group came to the conclusion that this was a reasonable time frame. I appreciate the feedback though and if anyone else reaches out saying it is too short I will increase the estimated time. Thank you!
Josh Corrigan -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 8
За всё время: 808
