HP Stream 11-d010nr Speaker Replacement
Выберете то, что вам нужно
  1. HP Stream 11-d010nr Speaker Replacement, Keyboard: шаг 1, изображение 1 из 2 HP Stream 11-d010nr Speaker Replacement, Keyboard: шаг 1, изображение 2 из 2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d010nr Speaker Replacement: шаг 2, изображение 1 из 1
    • Remove the eleven 5.6 mm Phillips #1 screws.
  3. HP Stream 11-d010nr Speaker Replacement: шаг 3, изображение 1 из 2 HP Stream 11-d010nr Speaker Replacement: шаг 3, изображение 2 из 2
    • Using an iFixit opening tool, pry open the case to separate the keyboard from the main body.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
  4. HP Stream 11-d010nr Speaker Replacement: шаг 4, изображение 1 из 1
    • Slowly lift the keyboard as there are multiple ribbon cables that could easily be damaged if lifted with force.
    • Carefully lift the keyboard and locate the three ribbon cables connecting the main body of the laptop to the keyboard.
  5. HP Stream 11-d010nr Speaker Replacement: шаг 5, изображение 1 из 3 HP Stream 11-d010nr Speaker Replacement: шаг 5, изображение 2 из 3 HP Stream 11-d010nr Speaker Replacement: шаг 5, изображение 3 из 3
    • Using your fingernail, lift the flaps on the ZIF connectors that are securing the three ribbon cables.
    • Carefully disconnect the three ribbon cables.
  6. HP Stream 11-d010nr Speaker Replacement: шаг 6, изображение 1 из 1
    • Lift the keyboard out of the laptop to remove it from the device.
  7. HP Stream 11-d010nr Speaker Replacement, Speaker: шаг 7, изображение 1 из 1
    • Undo 4 3mm screws attached to the speaker.
  8. HP Stream 11-d010nr Speaker Replacement: шаг 8, изображение 1 из 1
    • Remove connecting wire from the Motherboard.
  9. HP Stream 11-d010nr Speaker Replacement: шаг 9, изображение 1 из 1
    • Extract speakers after disconnecting.
Заключение
Tristan Thompson
Участник с: 10/03/22
97 Репутация
1 руководство автора
Команда
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 5
За последние 30 дней: 7
За всё время: 101
