Введение
If your HP Stream 11-d010nr is showing signs of a faulty or damaged wifi chip, such as being unable to consistently connect to a wifi signal, its wifi card may need to be replaced. This guide will show you the steps needed to do so.
Выберете то, что вам нужно
Pry off the two elliptical rubber inserts (one in each corner).
Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
Using an iFixit opening tool, pry open the case to separate the keyboard from the main body.
Carefully lift the keyboard and locate the three ribbon cables connecting the main body of the laptop to the keyboard.
Using your fingernail, lift the flaps on the ZIF connectors that are securing the three ribbon cables.
Carefully disconnect the three ribbon cables.
Remove any tape holding the battery connector in place.
Using your fingers, carefully unplug the battery.
Remove the four 3mm #000 Phillips screws holding the battery in place.
Carefully lift the battery out of the laptop.
Remove the one 3mm Phillips #000 screw holding the wireless chip in place.
Lift the wireless chip up and out.
Еще один человек закончил это руководство.
