HP Stream 11-r020nr Charging Port Replacement
Выберете то, что вам нужно
  1. HP Stream 11-r020nr Charging Port Replacement, Keyboard Panel: шаг 1, изображение 1 из 2 HP Stream 11-r020nr Charging Port Replacement, Keyboard Panel: шаг 1, изображение 2 из 2
    • Turn off your HP Stream 11-r020nr by holding the power button down for 10 seconds.
    • Turn the device top down so the rubber feet are facing up.
    • Use a metal spudger to remove all the rubber feet off of the bottom of the device, including the small ones. There will be a total of 11 screws to remove.
  2. HP Stream 11-r020nr Charging Port Replacement: шаг 2, изображение 1 из 1
    • Using the Phillips #1 screwdriver, remove all 11 of the the 5mm screws.
  3. HP Stream 11-r020nr Charging Port Replacement: шаг 3, изображение 1 из 2 HP Stream 11-r020nr Charging Port Replacement: шаг 3, изображение 2 из 2
    • Flip the laptop over and open the laptop.
    • Using the blue plastic opening tool, separate the keyboard plate from the main body by prying up starting around the bottom corners, prying the bottom up first and the sides second all the way around the whole keyboard plate.
    • Be gentle when lifting the keyboard up as there will be ribbon cables still attaching the keyboard to the base of the laptop.
  4. HP Stream 11-r020nr Charging Port Replacement: шаг 4, изображение 1 из 2 HP Stream 11-r020nr Charging Port Replacement: шаг 4, изображение 2 из 2
    • Use the black nylon spudger to flip the black tab up that holds the ribbon cable in place.
    • Lift the ribbon cable free.
  5. HP Stream 11-r020nr Charging Port Replacement: шаг 5, изображение 1 из 2 HP Stream 11-r020nr Charging Port Replacement: шаг 5, изображение 2 из 2
    • Use the black nylon spudger to flip the black tab up that holds the large ribbon cable in place.
    • Pull the ribbon cable free from the base of the keyboard.
  6. HP Stream 11-r020nr Charging Port Replacement: шаг 6, изображение 1 из 2 HP Stream 11-r020nr Charging Port Replacement: шаг 6, изображение 2 из 2
    • Remove the tape covering the ribbon cable.
    • Pull the ribbon cable away from the base of the laptop.
  7. HP Stream 11-r020nr Charging Port Replacement: шаг 7, изображение 1 из 1
    • After detaching the two large ribbon cables, carefully lean the keyboard against the screen.
  8. HP Stream 11-r020nr Charging Port Replacement, Charging Port: шаг 8, изображение 1 из 1
    • Pull the power cable away with your fingers.
  9. HP Stream 11-r020nr Charging Port Replacement: шаг 9, изображение 1 из 1
    • Using the Phillips #1 screwdriver, remove the 4 mm screw.
  10. HP Stream 11-r020nr Charging Port Replacement: шаг 10, изображение 1 из 1
    • Lift and remove the charging port from the device.
Заключение
Еще один человек закончил это руководство.
Victoria McGregor
Участник с: 04/09/18
556 Репутация
Автор 4 руководств
Команда
Eastern Washington University, Team S1-G1, Carnegie Spring 2018 Участник Eastern Washington University, Team S1-G1, Carnegie Spring 2018
EWU-CARNEGIE-S18S1G1
4 членов
Автор 8 руководств
2 Комментариев
my hp stream is not charging will be the problem
Nenwarang - Ответить
Hp stream 14 is not charging pls help me out battery is dropping down instead of going up
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 20
За всё время: 2,538
